Wi-Fi Combo
I am using BCM9WCD1EVAL1(P100) evaluation board with BCM943362WCD4(P200) ,But there is no schematic available for BCM9WCD1EVAL1(P100) in
"\WICED-SDK-3.5.2\WICED-SDK\platforms\evaluation_boards\BCM9WCD1EVAL1\schematics",
Where should i look for schematic of BCM9WCD1EVAL1(P100)
Or is there any other schematic similar to this ..
I found the schematic for BCM943362WCD4(P200).
Krishna.
ShawnA_01
Here are the BCM9WCD1EVAL1_P100 schematics.
MichaelF_56
I believe this is what you need: BCM43362 Evaluation Board Schematic (PDF)​
seyhan
Hi mwf_mmfae
In .../platforms/evaluation_boards/BCM9WCD1EVAL1/schematics directory there is no schematic for my "BCM9WCD1EVAL1(P100)" evaluation board .
All i found there is schematics for BCM9WCD1EVAL1_P200,BCM9WCD1EVAL1_P300,BCM9WCD1EVAL1_P400,P401,P402etc..
I need evaluation board schematic for
"BCM9WCD1EVAL1_P100"
SeyhanA_31
Base board schematics are part of the SDK, .../platforms/evaluation_boards.
Depending on the version of the BCM43362 base board, the schematics are located as part of the SDK in  .../platforms/evaluation_boards/BCM9WCD1EVAL1/schematics directory.
Seyhan
Hi seyhan
I searched in .../platforms/evaluation_boards/BCM9WCD1EVAL1/schematics directory. but i didn't find schematic threre...
But you shared previously link is the one i needed.
I need to know that which pins are mapped where in the Expansion Header J7..
I am using BCM9WCD1EVAL1 _P100 with BCM943362WCD4 module on it...
MichaelF_56
I have "BCM43362 Evaluation Board Schematic (PDF)"  this already
But i need the pin mapping of expansion header J7 Of "BCM9WCD1EVAL1 _P100" with "BCM943362WCD4 module" on it..
All i need is "Breakout Header pin mapping" of the BCM9WCD1EVAL1 _P100 evaluation board....
ShawnA_01
Is this what you are looking for?
Yes ,But this is for other eval board ...i will IMG_20160823_114358.jpgIMG_20160823_114412.jpgsend snap of my eval board...
ShawnA_01
Here are the snaps of EVAL Board
which schematic should i refer ..
ShawnA_01
<<<<which schematic should i refer ..
On 8/22 I provided the Revision P100 schematics.  Are you finding them inaccurate?
SeyhanA_31
Schematic attached with "BCM9WCD1EVAL1_P100.pdf" name is for the baseboard (black colored board.)
The red colored board schematic is released as part of the SDK, .../platforms/BCM943362WCD4/schematics/BCM943362WCD4_P200.pdf.
Seyhan
