Wi-Fi Combo
BeDe_2507241
New Contributor II
Is 802.11v currently supported? If yes, could you please clarify how the WNM Sleep Mode can be used?
Zhengbao_Zhang
Hello:
In the file command_console_wifi.c  ,  wnm_enable .
Zhengbao_Zhang
Hello:
  Would you please tell which chip is being asked ? thanks.
BeDe_2507241
New Contributor II
CYW43907 and BCM4343W
Zhengbao_Zhang
Hello:
I have a test by using latest 6.4 version,   43907  can support 802.11v  bsstrans function .
4343w is on testing, currently it can't run "wl wnm " enable command.   will continue tracking this function.
For wnm  we have an api in wifi command console, you can have a try .
BeDe_2507241
New Contributor II
Where is the command console you are referring to?
Zhengbao_Zhang
Hello:
AxLi_1746341
Honored Contributor
ZhengbaoZ_96 wrote:
Hello:
I have a test by using latest 6.4 version,   both 43907 and 4343w can support 802.11v  bsstrans function .
Can you also confirm if 43438 support 802.11v or not?
Seems does not work in my test:
> wnm get
Get WNM..Failed:
Zhengbao_Zhang
hello:
  Strange, I failed also in the test again, I will recall my test on 4343w, will update more info after my test,  thanks for the remind.
Zhengbao_Zhang
Correct my conclusion, will continue to verify 43438 wnm function, thanks a lot.
AxLi_1746341
Honored Contributor
Any update regarding "wnm get" fails on 43438?
Zhengbao_Zhang
Hello:
I found one test firmware for the wnm enable,  I can test the command successfully , but didn't setup environment for all 11v function test.
If you really want the function enabled in your project, suggest to raise help to module maker or FAE for the official release, thanks.
