USB superspeed peripherals
I am using AR0144 camera sensor which is interfaced to FX3.  I have doubt that what will be the RGB format in 12 bit data reception , for example will it be like RBG(4:4:4) or any other format. and what all the information will be there in 12 bit output data of AR0144.
Hemanth
Hi trilok,
Looking at the Image sensor specification, the output format that is streamed is RAW12.
So, each pixel data would be of 12 bits.
When Bayer filter is used in the image sensor, each pixel will capture only only color either red, green or blue.
Debayering is performed on this data to obtain red, green and blue components for each pixel.
To know more about how to reconstruct your image from the raw data, you would have to contact Image Sensor manufacturer.
Hemanth
Hemanth
Hemanth
Hi trilok,
Hemanth
Hemanth
Thank you for the information
