laze_4418921
25 sign-ins First solution authored 25 replies posted
     my firmware works well in 16bit mode. and now i want to change it to 32bit, GPIF has changed under the 16bit GPIF.  and other changes in the project are all in those photos .  but it seems can work, is there anything else need to change?
Thanks!
YiZ_31
Can you set io_cfg.useUart as cyFalse and see if it works? GPIO 53~ 56 are used as Uart port in 32-bit GPIF mode.
Eddie
YiZ_31
Eddie
thanks for your reply, i will  try it.
