fx3 thread create
gean_3054931
Level 5
Level 5
10 likes given 5 likes given First like received
if i create thread using CyU3PThreadCreate() API with stack size 0x400(1024),how many channels can i create using  CyU3PDmaChannelCreate() API.
help me,thank you
abhinavg_21
If you refer to the FX3 programmers guide you will find that the memory allocated for DMA Buffers is different from the RTOS stack memory (memory which is allocated to Threads) and hence DMA channels are independent of Thread memory.
Abhinav
abhinavg_21
Abhinav
