I could not find the above mentioned file neither in the Software Development kit nor at the Cypress site. Could you give me a download-link please ?
Kind regards
Pierre Hermans
Hello Pierre,
You can find those files in the AN65974.zip files https://www.cypress.com/documentation/application-notes/an65974-designing-ez-usb-fx3-slave-fifo-inte...
AN65974.zip is under the Related files heading.
I have also attached the zip folder.
Rashi
Rashi
Hello Pierre Herman,
From Fpga_slavefifo2b_vhdl, did you mean the .bit file for the configuration of FPGA?
You can find the zip file for configuration of FPGA throug FX3 from AN84868 https://www.cypress.com/documentation/application-notes/an84868-configuring-fpga-over-usb-using-cypr...
If this is not what you were looking for, please let us know in details.
Rashi
Rashi
Hello Rashi,
I meant the vhdl file(s), which are mentioned in AN65974 Chapter13 as
" Associated
Project Files " In Chapter12 of this application note the graphical
statemachines are mentioned
With kind regards
Pierre Hermans
On Tue, 8 Oct 2019 at 13:41, RashiV_61 <community-manager@cypress.com>
Hello Pierre,
Rashi
Rashi
I found them. Thank you very much Rashi.
Kind regards
Pierre Hermans
On Tue, 8 Oct 2019 at 14:25, RashiV_61 <community-manager@cypress.com>
