USB superspeed peripherals
erho_283561
New Contributor II
        I am building a FX3 to Compact Flash GPIF bridge. When changing from 8 bit to 16 bit data bus, the GPIO pins for the data and address bus change. Unfortunately, I do not under stand how to interpret GPIO46:28 for the address bus? Which pins are the address bus? When configured as an 8 bit, the address bus is labeled GPIO8:13. So that means the address pins are GPIO 8, GPIO 9, GPIO 10, GPIO 11, GPIO 12 and GPIO 13. In both cases, the number of address pins used should be 6. Also, I have used GPIOs 17-25 for Compact Flash signals. Regards, Eric
        Hi Eric, You should be able to see the pins allocated for address bus if you place cursor on the GPIO46:28 (as shown in the attached figure). They are GPIO 28, 29, 46, 47, 48, 49. Thanks, sai krishna.
