USB superspeed peripherals
SureshJ
New Contributor
1.Please confirm whether the AC capacitors are required between the Type-C connector and the MUX (PI5USB30213AXEA) input on TX lines.
2.Shall i keep the VCONN pin floating in the PI5USB30213AXEA MUX IC. Please confirm.
Suresh
JayakrishnaT_76
Hello Suresh,
Please refer to the following KBA:
https://community.infineon.com/t5/Knowledge-Base-Articles/Designing-Type-C-products-based-on-EZ-USB-...
The above KBA has reference schematics (of the type C section) for FX3/CX3 based type C products. Based on your requirement (receptacle or plug), you can refer to the appropriate schematics and use it for your design.
Jayakrishna
JayakrishnaT_76
Hello Suresh,
Please let us know which product that is used as the USB 3.0 controller. Is it FX3 (CYUSB3014)?
Jayakrishna
SureshJ
New Contributor
Dear Jayakrishna,
We are using CX3 ( CYUSB3065). Please let me know if you need any other details.
Suresh
JayakrishnaT_76
Hello Suresh,
Jayakrishna
SureshJ
New Contributor
Dear Jayakrishna,
From the link that you have provided, i hope that AC capacitors are needed on the TX lines.
Coming to my second question, VCONN is left floating in your reference schematic ( receptacle ) as well. So, I hope that we can leave VCONN in floating state. It should not create any issues. Please confirm once.
Suresh
JayakrishnaT_76
Hello Suresh,
Yes, your understandings are correct. Also, please check if your MUX internally has a re-driver. If it has a re-driver inside it, then please use AC caps on input and output of the MUX as shown in section 3 of the KBA mentioned before.
Jayakrishna
SureshJ
New Contributor
Dear Jayakrishna,
Suresh
JayakrishnaT_76
Hello Suresh,
Yes, you can leave it floating as shown in the KBA.
Jayakrishna
