USB superspeed peripherals
Hi ,
  How to modify the "FriendlyName" of descriptor?
I can't found this descriptor in descriptor .c file.
For changing the friendly name of the device you have to edit the STRINGS section of the inf file that is used to bind the device.Provide the name of the device at the appropirate place (wrt VID/PID) IN strings section.
Vikas.
