USB superspeed peripherals
MaXi_1246331
Contributor
I have a PCB with FX3. An EEPROM is used to store firmware. I can reprogram the EEPROM using console center, but I do not not how to erase I2C EEPROM connected with FX3. Please tell me if your know. Thank you.
YiZ_31
Hi ,
May I know why do you want to erase EEPROM? We do not have API for FX3 to directly erase the EEPROM. You can just overwrite the data you do not want.
Eddie
YiZ_31
Hi ,
Eddie
MaXi_1246331
Contributor
I do not have to erase the EEPROM. Thank you. This question is well answered
