I want to change the DMA burst length and buffer size. The firmware I'm using is the SlaveFifoSync, which I downloaded from the AN65974. I notice that the the default setting is following(sorry, I can't find how to insert code):
#ifdef STREAM_IN_OUT
#define BURST_LEN 16
#define DMA_BUF_SIZE (16)
/* Slave FIFO P_2_U channel buffer count */
#define CY_FX_SLFIFO_DMA_BUF_COUNT_P_2_U (4)
/* Slave FIFO U_2_P channel buffer count */
#define CY_FX_SLFIFO_DMA_BUF_COUNT_U_2_P (8)
#endif
So I change the setting like this:
#define CY_FX_SLFIFO_DMA_BUF_COUNT_P_2_U (1)
#define CY_FX_SLFIFO_DMA_BUF_COUNT_U_2_P (1)
#endif
It works fine for my application. But the DMA buffer is still large. It spends about 6 seconds for data to fill the 16KB buffer. So I want to continue to reduce the DMA buffer size. The setting is following:
#define BURST_LEN 2
#define DMA_BUF_SIZE (2)
#endif
The buffer size is 2KB. But the data transfer failed. I don't know where is the problem. Maybe I made the wrong amendment, or I need to continue to modify something else. Thanks for any advice.
Hello Jerry,
The endpoint configuration are different in the main code (cyfxslfifosync.c file) and the usb descriptors const uint8_t CyFxUSBSSConfigDscr[] (cyfxslfifousbdscr.c)
Please make the changes as mentioned in the attachment.
If this doesn't help,please let me know what is the error that occurs.
Rashi
Rashi
Hello Jerry,
Rashi
Rashi
