USB superspeed peripherals
LiMa_282146
New Contributor II
Could someone confirm the pcb pad sizes for the FX3 BGA package. Cypress application note AN70707 p2 gives the recommended pad size as 0.241mm but the development board has a pad size of about 0.5mm. Has anyone built a pcb using the recommended pad sizes for the FX3.
Sodafarl
Please create a support case (MyAccount -> MyCases) for this so that one of our engineers can look into this.
Anand
LiMa_282146
New Contributor II
Pad size query has been answered by Cypress Technical support. Pad size is as specified in application note AN70707 at 2.4mm (9.5mil).
Sodafarl
LiMa_282146
New Contributor II
Sorry this should be 0.24mm
Sodafarl
