I am trying to program two different SPI nor flash memories using the Control Center.
To do so, I want to use a GPIO from the FX3 to control a digital switch before programing.
Is there any way to manage any GPIO with FX3 in bootloader mode?
Thank you!
USB Superspeed Peripherals
Sorry to misunderstand your question.
The GPIO cannot be driven without downloading any firmware in the device.
As it is a ROM Bootloader, and hence it cannot be modified to drive a GPIO. You can try using a second stage bootloader if you want to write to both the SPI Flash or you can use a switch so that only one Flash is selected at a time.
Rashi
Please refer to section 11 of this app note https://www.cypress.com/file/201991/download for the default state of the FX3 I/Os for the different boot modes, while the bootloader is executing before application firmware download).
Rashi
Hi Rashi,
thank you for the quick feedback.
In this section, the default state of the I/O are described, but I am asking if I can change the state of a certain GPIO without downloading any firmware in the device.
Rashi
Okay, understood. I will try to use the second stage bootloader.
Thank you very much!
