USB superspeed peripherals
Hi all,
I am a Beginner of the CX3.
I would like to implement USB Camera by referring to Denebola RDK. (Connection with smartphone)
If you look at the E-Con Systmems homepage, you can see the supported OS list as below.
- Windows 10
- Windows 8
- Windows 7
- Linux
(Cypress EZ-USB® CX3 camera reference design kit (RDK)​)
I want to know if the SW supports Android.
Or is there a history of working with Android based on the SW provided by E-Con Systems?
I am grateful for all the relevant answers.
abhinavg_21
Yes it is possible to interface e-con camera with android only if your android version supports UVC drivers.
You need an application that will talk to driver. You can check with e-Con systems. Please check the following link:
Webeecam - Android USB Camera App
-Regards
Abhinav
abhinavg_21
-Regards
Abhinav
