- Email to a Friend
Do the "BULK Stream" will be available soon?
Or someone has writen an driver that support it ?
If someone did it, can you give me your transfert rate ? (and the USB Controller used)
Thanks !
- Email to a Friend
Have you look at C:\Cypress\FX3 SDK\firmware\basic_examples\cyfxbulkstreams after installing the SDK?
Anand
- Email to a Friend
Yes I have already trying that, but it's impossible to make it work.
In addition, in the CySuiteUSB3 V1.0.0.B209 ReleaseNotes ( C:\Cypress\Cypress SuperSpeed USBSuite\ReleaseNotes.pdf )
Its written in the third paragraph : "USB3.0 Bulk streaming operation is not supported."
Do you know when it will be available ? In the next rev. ? soon ?
- Email to a Friend
Had a discussion with our guys
None of the current host stack support bulk stream but the firmware has been tested internally and we know that it works. So you'll most probably have to wait till a host stack which supports bulk stream comes to market.
Anand
- Email to a Friend
Can you explain me where is the problem ?
FX3 firmware, FX3 Driver, or API ?
- Email to a Friend
The host stack to which the host side driver should talk to. That is where the problem is.
We've a firmware which we know works. So everything is ready on the firmware side. We've to wait for host to support it.
Going by your thread it seems bulk stream is the only way to meet the requirement for your design. If this is the case then please create a tech support case (MyAccount -> MyCases) so that we also get a proper understanding of the requirement and see how we can help you better.
Anand
