I have implemented a Slave FIFO interface between the FPGA and FX3.
But it seems like there are some configuration issues. I cannot get the interface working yet.
When ever I use CyU3PGpifGetSMState() API it always gives zero as the current state. When I check in GPIF Designer, the LOGIC_ONE condition is put in between RESET and IDLE states.
Therefore, I think I should not get Reset state. How can this happen? Can someone please explain?
Thank you.
Hi Pradeepa Senanayake,
Please let su know what are the changes you have made and also what exactly is the issue you are facing ?
Krishna.
I mean the changes you have made in the SlaveFIFO firmware.
This issue is solved. The issue was related to the connection between FX3 and FPGA. Now it is properly working.
