ShYa_3490236
Distributor - Macnica (Japan)
10 solutions authored 50 replies posted 50 sign-ins
I'm currently using the EZ-USB FX3 SDK v1.3.3 but cannot build the F/W normally on window 10 platform.
As a result of building the same source code on Windows 7, I had confirmed that there is a mismatch by the binary level between windows 10 and windows 7.
Could you let me know the suitable SDK version that Windows10 is officially supported? or provide the solution for above issue?
Please let me know if you need more information.
Shohei
HirotakaT_91
500 replies posted 250 replies posted 100 replies posted
As of Jan 2020, latest FX3 SDK is 1.3.4. It has released from May 2018.
https://www.cypress.com/documentation/software-and-drivers/ez-usb-fx3-software-development-kit
Could you try to use SDK 1.3.4 and let me know if your issue is solved?
Hirotaka Takayama
HirotakaT_91
Hirotaka Takayama
ShYa_3490236
Hi Takayama-san,
Thanks for always and early response.
Got it, I plan to confirm the phenomenon by latest SDK version later.
Let you know if any.
Shohei
