I use CYUSB3KIT-003 as a USB to I2C convert device, I dont know how to let the I2C to support Clock-stretching. Please give me some advice, thanks!!
ispn:38621:1:0
l1:314:1:0
- i2c clock-stretching
You need not do any code changes in firmware. The I2C block of FX3 will support clock stretching by design.
Jayakrishna
FX3's I2C interface can only work as an I2C master and it supports clock stretching feature by design. Please refer to the Section I2C interface in FX3 datasheet which already mentions this. The link to the datasheet is given below:
Jayakrishna
Thanks for your quickly echo, To support the clock-stretching ,Is there any special codes we need in my firmware? or the device support the clock-stretching naturally?
Jayakrishna
