USB superspeed peripherals
bayi_4531756
New Contributor
I get a depth sensor to connect to CX3. Now I can get the frame data on the host. But there is always data flicker in frame. I use the CyU3PMipicsiSetPhyTimeDelay to set the physical value and adjust the physical value. But the data flicker always exists. So what could be the problem? The following figure is mipi error log. Can any guy explain the variable in struct CyU3PMipicsiErrorCounts_t?
KandlaguntaR_36
Please refer the following KBA MIPI-CSI Protocol and Physical Layer Errors in CX3 (CYUSB3065 and CYUSB3064) – KBA228482
Please share the screenshot of MIPI tool receiver configuration tab to check whether you have set a valid configuration.
Sridhar
KandlaguntaR_36
Sridhar
