USB superspeed peripherals
veRN_2322216
New Contributor II
hi guys ...
             Actually we are using cypress streamer and control center to fetch data from FX3 to PC .
and we are sending data from FPGA to FX3 @ 100 Mhz frequency, but when we will recieve the data at pc the data is some what shifting as i attached below ...
and the input image to FPGA also i attached (151.jpg is the inputa nd smallfilename32.jpg is the file written by streamer .)can any one tell me why the streamer data is shifting,if i want fix this problem what exactly i have to do .
can any one help me ? to sort out this problem.
thanks  regards,
veerendra
