USB superspeed peripherals
lopo_1264666
New Contributor II
Table 5 listed combinations of burst length, buffer size and no of buffers to give different throughputs.
How to modify cyfxbulksrcsink.h parameters to simulate these cases using FX3 SuperSpeed Explorer Kit?
CY_FX_EP_BURST_LENGTH = burst length?
CY_FX_BULKSRCSINK_DMA_BUF_COUNT = no of buffers?
How about buffer size, which parameter to be modified?
As for Table 6 for Isochronous transfer,
CY_FX_ISO_BURST = burst length?
CY_FX_ISO_PKTS = iso-packets?
CY_FX_ISOSRCSINK_DMA_BUF_COUNT = no of buffers?
Rashi_Vatsa
The data throughput for different transfers can be tested on super speed explorer kit also as it has CYUSB3014 part (with 512 KB SRAM)
- Please confirm that you are using firmware files with the application note.
- For isochronous transfers you need the modify the following macro  values in cyfxisosrcsink.h according to table 3 or table 4 and test using the streamer application
- For Bulk transfers you need  you need the modify the following macro  values in cyfxbulksrcsink.h according to table 5 or table 6 and test using the streamer application
Please let me know if any query on this
Rashi
Rashi
Rashi_Vatsa
Rashi
Rashi
