I had download AN75779.zip(http://www.cypress.com/file/123501/download) 03/24/2016
use fpga to creat data
the example is 8bit with 30fps works fine then i change to 16bit with 60fps still works fine
but when i change to 32bit (60fps and 120fps) the problem occur the data didn't transfer thought usb
follow the pdf i sure isDQ32bit is true both counters is 4091 and SPI is false
this is the list what i changed:
X,Y dimension ratio to 5:4
height to 1024
fps to 120
frame size to 2621440 (1280*1024*2)
which those in VS format descriptor / VS frame descriptor / UVC Probe control settings
In GPIF setting
change data bus width to 32bit
delete sensor_reset pin
change LD_data_counter/LD_addr_counter to 4091
So why this problem happen and whats special for 32bit mode?
1) Please clarify what do you mean by data didn't transfer. I suppose the device enumerated on the PC and came up as a imaging device.
2)Connect a USB-UART bridge and check which FX3 API is getting failed. Please put debug print to count the number of producer and consumer event. Please report what do you see on the UART.
