USB low-full-high speed peripherals
MaHo_4028756
First like given Welcome!
I just detected the KBA89285 -> https://community.cypress.com/docs/DOC-10959​ and use the unique serial number in my firmware for a DSO. However, I wonder why this important functionality is not mentioned in the TRM.
Martin
YatheeshD_36
Moderator 750 replies posted 500 replies posted 250 solutions authored
The KBA EZ-USB® FX2LP™ Unique ID Registers – KBA89285  addresses registers of FX2LP in particular.
KBAs generally contain information on specific products which are not present in the documents and which may be helpful in the process of development. They are created depending on the requirements and queries on a product.
We will consider your suggestion and we will update the document based on the requirements.
Yatheesh
YatheeshD_36
Yatheesh
MaHo_4028756
Thank you for the quick response! Are there any other hidden secrets of the FX2LP?
YatheeshD_36
There are information about the FX2LP product usage and applications which are documented in KBAs and many answers for your questions can be found out in previously answered threads. You can go through Cypress Developer Community​ for the same.
Please find the KBAs on FX2LP here: Knowledge Base Articles
Yatheesh
