USB low-full-high speed peripherals
Hello!
I want to implement UVC using FX3 (trying on SuperSpeed Kit). There is no problem with UVC examples from SDK, but I have no luck to modify USBVideoClass example to work with uncompressed frames. I've downloaded specs from USB.org - USB Device Class Specifications and changed format and frame descriptors as described. I've also changed Probe and Commit control structs.
Is there any example of FRAME_UNCOMPRESSED video translation?
v4l2-ctl output:
v4l2-ctl --all -d0
Driver Info (not using libv4l2):
Driver name   : uvcvideo
Card type     : FX3
Bus info      : usb-0000:00:14.0-5
Driver version: 4.15.18
Capabilities  : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps   : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height      : 32/24
Pixel Format      : 'BGR3'
Field             : None
Bytes per Line    : 96
Size Image        : 2304
Colorspace        : Default
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization      : Default (maps to Full Range)
Flags             :
Crop Capability Video Capture:
Bounds      : Left 0, Top 0, Width 32, Height 24
Default     : Left 0, Top 0, Width 32, Height 24
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 32, Height 24
Selection: crop_bounds, Left 0, Top 0, Width 32, Height 24
Streaming Parameters Video Capture:
Capabilities     : timeperframe
Frames per second: 25.000 (25/1)
Read buffers     : 0
I'm using guvcview utility to check results. And here is the log:
V4L2_CORE: (get_v4l2_frame) video stream must be started first
lsusb output:
Bus 001 Device 047: ID 04b4:4722 Cypress Semiconductor Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2 ?
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x04b4 Cypress Semiconductor Corp.
  idProduct          0x4722
  bcdDevice            0.00
  iManufacturer           1 Cypress
  iProduct                2 FX3
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength          198
    bNumInterfaces          2
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              400mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass         14 Video
      bFunctionSubClass       3 Video Interface Collection
      bFunctionProtocol       0
      iFunction               0
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass        14 Video
      bInterfaceSubClass      1 Video Control
      bInterfaceProtocol      0
      iInterface              0
      VideoControl Interface Descriptor:
        bLength                13
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdUVC               1.00
        wTotalLength           80
        dwClockFrequency       48.000000MHz
        bInCollection           1
        baInterfaceNr( 0)       1
        bLength                18
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             1
        wTerminalType      0x0201 Camera Sensor
        bAssocTerminal          0
        iTerminal               0
        wObjectiveFocalLengthMin      0
        wObjectiveFocalLengthMax      0
        wOcularFocalLength            0
        bControlSize                  3
        bmControls           0x00000000
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      5 (PROCESSING_UNIT)
      Warning: Descriptor too short
        bUnitID                 2
        bSourceID               1
        wMaxMultiplier      16384
        bControlSize            3
        iProcessing             0
        bmVideoStandards     0x1c
          PAL - 625/50
          SECAM - 625/50
          NTSC - 625/50
        bLength                28
        bDescriptorType        36
        bDescriptorSubtype      6 (EXTENSION_UNIT)
        bUnitID                 3
        guidExtensionCode         {ffffffff-ffff-ffff-ffff-ffffffffffff}
        bNumControl             0
        bNrPins                 1
        baSourceID( 0)          2
        bControlSize            3
        bmControls( 0)       0x00
        bmControls( 1)       0x00
        bmControls( 2)       0x00
        iExtension              0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             4
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bSourceID               3
        iTerminal               0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Video Streaming
      iInterface              0
      VideoStreaming Interface Descriptor:
        bLength                            14
        bDescriptorType                    36
        bDescriptorSubtype                  1 (INPUT_HEADER)
        bNumFormats                         1
        wTotalLength                       71
        bEndPointAddress                  131
        bmInfo                              0
        bTerminalLink                       4
        bStillCaptureMethod                 1
        bTriggerSupport                     1
        bTriggerUsage                       0
        bControlSize                        1
        bmaControls( 0)                    27
        bLength                            27
        bDescriptorType                    36
        bDescriptorSubtype                  4 (FORMAT_UNCOMPRESSED)
        bFormatIndex                        1
        bNumFrameDescriptors                1
        guidFormat                            {7deb36e4-4f52-ce11-9f53-0020af0ba770}
        bBitsPerPixel                      24
        bDefaultFrameIndex                  1
        bAspectRatioX                       0
        bAspectRatioY                       0
        bmInterlaceFlags                 0x00
          Interlaced stream or variable: No
          Fields per frame: 2 fields
          Field 1 first: No
          Field pattern: Field 1 only
          bCopyProtect                      0
        bLength                            30
        bDescriptorType                    36
        bDescriptorSubtype                  5 (FRAME_UNCOMPRESSED)
        bFrameIndex                         1
        bmCapabilities                   0x00
          Still image unsupported
        wWidth                             32
        wHeight                            24
        dwMinBitRate                   460800
        dwMaxBitRate                   921600
        dwMaxVideoFrameBufferSize        2304
        dwDefaultFrameInterval         400000
        bFrameIntervalType                  1
        dwFrameInterval( 0)            400000
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength           22
  bNumDeviceCaps          2
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000002
      Link Power Management (LPM) Supported
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x00
    wSpeedsSupported   0x000e
      Device can operate at Full Speed (12Mbps)
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   3
      Lowest fully-functional device speed is SuperSpeed (5Gbps)
    bU1DevExitLat           0 micro seconds
    bU2DevExitLat           0 micro seconds
Device Status:     0x0000
  (Bus Powered)
abhinavg_21
Please try to stream the video using example firmware that comes along with the FX3SDK "C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\firmware\uvc_examples\cyfxuvcinmem" and share the the result.
Have you installed the "v4l2_utils" on the PC?
If still its not working try to change descriptors in AN75779 according to your image sensor & video requirement.
Thanks & Regards
Abhinav
abhinavg_21
The UVC example from SDK uses a pre-stored MJPEG video frames. I guess you want to stream the video frames from an image sensor. Please make certain changes in the AN 75779. This AN makes use of sensor configuration and stream image live from the sensor.
Following is the link to download AN and its code:
http://www.cypress.com/documentation/application-notes/an75779-how-implement-image-sensor-interface-...
Thanks & Regards
Abhinav
Thank you for very useful example! My descriptors are very similar to one from AN 75779. And I can't see any error in mine.
Here is dmesg output with uvcvideo debug enabled:
[1635852.910451] usb 1-1: new high-speed USB device number 60 using xhci_hcd
[1635853.059635] usb 1-1: New USB device found, idVendor=04b4, idProduct=4722
[1635853.059641] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[1635853.059645] usb 1-1: Product: FX3
[1635853.059649] usb 1-1: Manufacturer: Cypress
[1635853.060257] uvcvideo: Probing generic UVC device 1
[1635853.060265] uvcvideo: Found format BGR 8:8:8 (BGR3).
[1635853.060268] uvcvideo: - 32x24 (25.0 fps)
[1635853.060278] uvcvideo: Found a Status endpoint (addr 82).
[1635853.060281] uvcvideo: Found UVC 1.00 device FX3 (04b4:4722)
[1635853.060286] uvcvideo: Scanning UVC chain: OT 4 <- XU 3 <- PU 2 <- IT 1
[1635853.060297] uvcvideo: Found a valid video chain (1 -> 4).
[1635853.060805] uvcvideo 1-1:1.0: Entity type for entity Extension 3 was not initialized!
[1635853.060810] uvcvideo 1-1:1.0: Entity type for entity Processing 2 was not initialized!
[1635853.060814] uvcvideo 1-1:1.0: Entity type for entity Camera 1 was not initialized!
[1635853.060995] input: FX3 as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/input/input86
[1635853.061142] uvcvideo: UVC device initialized.
[1635853.121282] uvcvideo: uvc_v4l2_open
[1635853.121333] uvcvideo: uvc_v4l2_release
[1635853.123896] uvcvideo: uvc_v4l2_open
[1635853.123905] uvcvideo: uvc_v4l2_release
[1635853.124058] uvcvideo: uvc_v4l2_open
[1635853.124063] uvcvideo: Control 0x00980900 not found.
[1635853.124064] uvcvideo: Control 0x00980901 not found.
[1635853.124065] uvcvideo: Control 0x00980902 not found.
[1635853.124065] uvcvideo: Control 0x00980903 not found.
[1635853.124087] uvcvideo: Control 0x00980928 not found.
[1635853.124087] uvcvideo: Control 0x00980929 not found.
[1635853.124088] uvcvideo: Control 0x0098092a not found.
[1635853.124088] uvcvideo: Control 0x08000000 not found.
[1635853.124089] uvcvideo: uvc_v4l2_release
[1635853.124657] uvcvideo: uvc_v4l2_open
[1635853.124664] uvcvideo: uvc_v4l2_release
[1635858.910488] uvcvideo: Suspending interface 1
[1635858.910491] uvcvideo: Suspending interface 0
[1635903.112139] uvcvideo: uvc_v4l2_open
[1635903.226947] uvcvideo: Resuming interface 0
[1635903.226950] uvcvideo: Resuming interface 1
[1635903.227933] uvcvideo: uvc_v4l2_release
[1635903.228683] uvcvideo: uvc_v4l2_open
[1635903.229727] uvcvideo: Control 0x00980900 not found.
[1635903.229732] uvcvideo: Control 0x00980901 not found.
[1635903.229735] uvcvideo: Control 0x00980902 not found.
[1635903.229739] uvcvideo: Control 0x00980903 not found.
[1635903.229969] uvcvideo: Control 0x009a091d not found.
[1635903.229972] uvcvideo: Control 0x009a091e not found.
[1635903.229976] uvcvideo: Control 0x009a091f not found.
[1635903.229979] uvcvideo: Control 0x08000000 not found.
[1635903.389051] uvcvideo: Trying format 0x33524742 (BGR3): 32x24.
[1635903.389052] uvcvideo: Using default frame interval 40000.0 us (25.0 fps).
[1635903.389671] uvcvideo: uvc_v4l2_mmap
[1635903.389674] uvcvideo: uvc_v4l2_mmap
[1635903.389676] uvcvideo: uvc_v4l2_mmap
[1635903.389678] uvcvideo: uvc_v4l2_mmap
[1635903.389684] uvcvideo: Setting frame interval to 1/25 (400000).
[1635903.909757] uvcvideo: Setting frame interval to 1/25 (400000).
[1635908.931445] uvcvideo: uvc_v4l2_release
[1635910.934850] uvcvideo: Suspending interface 1
[1635910.934853] uvcvideo: Suspending interface 0
Could you tell what is going wrong with my firmware?
abhinavg_21
Thanks & Regards
Abhinav
