anga_4847821
I need breakout USB to UART interface module based on CY7C65213A.Do you have, kindly let me know. Can you clarify that Is there any module with CY7C65213A.I have seen the USB UART Serial Breakout- CY7C65213 but it is not suitable for RS485.So I want USB UART Serial Breakout with CY7C65213A.
Can you tell me the hardware difference of both IC's. Do you have the USB UART CY7C65213A breakout
YatheeshD_36
Hello Anil,
As discussed, the CY7C65213A part is pin compatible with the CY7C65213. Hence, any board that has a CY7C65213 IC can be replaced with corresponding pin-compatible CY7C65213A.
Yatheesh
YatheeshD_36
CY7C65213 and CY7C65213A are pin compatible and there is no difference in hardware.
You can make use of CYUSBS232 RDK and replace the CY7C65213 IC on the RDK with CY7C65213A part.
Yatheesh
Dear Sir,
We gone through your message.But we want that breakout board have an IC of
CY7C65213A.Can you mount that IC and you will able supply to me means it is
OK for us or if you give CY7C65213A IC and breakout board with same rate
also ok. Because we are doing R&D ,So we can't afford the expenses.
Kindly let me know.
Anilkumar Galla
Scita Solutions
Bangalore
On Tue, Dec 29, 2020 at 2:25 PM YatheeshD_36 <community-manager@cypress.com>
YatheeshD_36
Hello Anil,
Yatheesh
