EZUSB-FX2 firmware recovering
9875V
Hello everyone ,
I'm currently working with an ezusb FX2 board and we are using an old firmware downloaded by the 32bits driver ezloader.sys i'm working on using the component with a 64bits processor. The problem is that i dont know how to get the firmware . I would like to read the ram of the component to retireve it after loading it in the board with the 32bits computer.  I will then load it using CyControlCenter on the 64bits computer if i can read the ram and get the firmware as an .hex maybe .
Thanks for your help.
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
As per my understanding , ezloader is only used for firmware download. You need the hex file. It would not be possible to retrieve back the same file. Do you not have have the project/hex file now?
MallikaK_22
i have the ezloader.sys loading the right firmware but i dont know how to get the hex file of the firmware( who is compiled into ezloader) as i don't have the source files of ezloader.
MallikaK_22
Unfortunately I don't think it will be possible to retrieve back the hex file that is already loaded.
