USB low-full-high speed peripherals
Hi!
 Is there any software examples of usb transfer functions on Borland C++ Builder? I found only programs on  Visual Studio.
I find FxEEPROM example on Builder in SuiteUSB, but can anyone help to find usb transaction function there?
 Shambh
Can you please post the application here?
It has been long since we have withdrawn support for Borland C++ applications. We do not use them internally.
So if you post the application, maybe one of us can have a look and help you out.
Nikhil
 MainF.cpp in attached file.
Once again, application in attached file, did not work in last post. And one more question, i copy this example in Builder 6, and  the following error appeared: "Project FxEEPROM.exe raised exception class EAccesViolation with message 'Access violation at address 00471AAE  in module 'FxEEprom.exe'. Write of address 0017FEBO'". Does anyone know what it mean?
Try attaching it as a zip file from Mozilla.
Gayathri
Trying one more time.
 Hm, then you can download it from here: http://www.4shared.com/zip/SQdsBVWc/FxEEPROM.html
