I went through the driver resell process for cyusb3 for win10, and it appears to be installing and working. Excellent, thank you. However, the modified driver package that I submitted only included our company's USB devices (VID/PIDs). I would like to also add a default Cypress VID/PID to our INF so that we can easily program new/blank boards we receive. From the CyUSB.pdf this seems perfectly fine ? I wanted to check before submitting another modified package on the microsoft hw dashboard.
Specific questions:
1. Are third parties allowed to add Cypress VID/PIDs to their driver package for resell ?
2. If I can add Cypress VID/PIDs (or if I need to add our own new VID/PID), do I need to submit this new INF to cypress or can I just upload another modified driver package to the dashboard (same as initial one)?
2.a. If I need to submit an INF to cypress first, how would I go about doing that now that technical cases are gone ?
Erik
Hello Erik,
- Third party vendors are generally not allowed to add Cypress VID/PID in the CyUSB3.INF file. The problem is that when you push the driver for Windows Update, the Cypress VID/PID also gets pushed to the WU. This can cause problems when other customers use the same Cypress VID/PID and the driver comes up with a different name string.
Srinath S
Hello Erik,
Srinath S
Thanks that makes sense. I think internally we'll probably enable test-signing on the machine(s) and use an unsigned driver for initial programming.
