USB low-full-high speed peripherals
 Can CY7C68013A fifoadr[1:0] be configured by a register not by the pins.
I want to save two pins and the fifoadr[1:0] is always 10
that will never change.
No, that is not possible.
The endpoint can oly be selected by externally driving the FIFOADR pins. You can connect two output GPIO's to these two pins and control them through FX2LP firmware itself, if required.
Shashank
what did you mean by save two pins?
Gayathri
