USB low-full-high speed peripherals
SuSh_1535366
Contributor II
Maximum 18 mA is specified as the total power consumption of Vcc and Vccio in the data sheet of CY8C65213.
I want to know the power consumption Vcc and Vccio separately.
Please teach me the power consumption each power-pin.
Shimamura
I believe the part number is "CY7C65213" (instead of CY8C65213).
We do not have the individual values as it is completely application specific. We encourage you to measure it in your test environment.
- Madhu Sudhan
- Madhu Sudhan
SuSh_1535366
Contributor II
Oh, I made a mistake, CY7C65213 is the correct part number.
And I understood your answer.
Thank you for your reply.
Shimamura
