A 216MHz noise for my CY7C68014A
eran
First question asked Welcome!
Hello
I ran an radiated RF emission test, and got a 216MHz noise from the CY7C68014A. The crystal frequency is 24MHz and the PLL microcontroller can increase the clock frequency up to 480MHz. How can I overcome this noise?
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
Could you please check High-Speed USB PCB Layout Recommendations in the App Note: https://www.cypress.com/file/135006/download
Mallika
zzz_3221081
Level 5
Level 5
25 solutions authored 100 sign-ins 10 likes received
I am more of a SW guy, but I couldn't help but notice that 24 * (2 * 2 * 2) + 24 = 216, the frequency you measured.
Probably a mixing of the third harmonic with the base frequency.
From my limited HW design knowledge I gathered, the source is often the supply lines, less often driven IO lines. Perhaps you need to add some RF filtering.  Buffer caps (electrolytic caps) are very bad at this.
MallikaK_22
Mallika
