Hi
our system is NVIDIA Jetson Xavier NX
when USB3.0 SSD unplug form Jeston " native USB3 port", OS can show unplug device information.
but when USB3.0 SSD unplug form CYUSB3314-88LTXI USB3.0 Hub, OS have to wait a long time and then show the unplug device information.
can I fix the issue?, I want CYUSB3314 have the same behavior as native port.
Hi Dimitry,
As per the USB 3.2 specification, the Hub shall detect a disconnect in 12ms, and then the host will be notified. HX3 was tested against these test cases.
Ajeeth
Hi Dimitry,
Ajeeth
Hi Dimitry,
To debug further in your case, do you have a USB analyzer? If so, is it possible to check if the hub sends the Port disconnect notification to the host as soon as the port is disconnected?
Ajeeth
