Regarding IEC61000-4-2 spec(Contact Discharge and Air Discharge) of CY7C65632-28LTXC(HX2VL)?
YuMa_1534086
Level 7
Level 7
Distributor - Macnica (Japan)
500 replies posted 250 sign-ins 10 likes received
Q1)
Could you please let us know IEC61000-4-2 spec(Contact Discharge and Air Discharge) of CY7C65632-28LTXC(HX2VL)?
Q2)
Is IEC61000-4-2 spec(Contact Discharge and Air Discharge) of CY7C65632-28LTXC(HX2VL) the same as CY7C65642-48AXCT(HX2VL_TetraHub)?
Best Regards.
Yutaka Matsubara
HirotakaT_91
500 replies posted 250 replies posted 100 replies posted
Hi Matsubara-san,
A1) A2)
CY7C65632 has internal ESD protection diodes on all I/O pins.
These diodes are capable of protecting ESD against up to 4000V ESD-HBM as per corresponding Product Qualification Report.
https://www.cypress.com/documentation/qualification-reports/qtp-110306-cy7c6563242-ssmc-product-qual...
If your (customer) board needs to meet the IEC61000-4-2 spec, adding to external ESD protection diodes is needed.
Hirotaka Takayama
HirotakaT_91
Hi Matsubara-san,
A1) A2)
Hirotaka Takayama
YuMa_1534086
Level 7
Level 7
Hi Takayama-san
Thank you for your reply.
I understood.
Best Regards.
Yutaka Matsubara
