Hi
They are using CY7C65632, but it seems that the eye pattern opening on the DS port is narrower. Is ther any method to adjust the Eye pattern? or Tool?
Best Regards
Arai
HX2VL doesn't have a feature to config parameters such as pre-emphasis.
Do kindly check schematic, component, and layout design whether it meets AN72332.
Hirotaka Takayama
Hirotaka Takayama
Hi takayama san
Just in case, Is it okay to understand that even with Blaster Plus, this eye pattern can not be adjusted?
Best Regards
Arai
Hi Arai-san,
In case of using HX3 Blaster Plus (not Blaster), they can change pre-emphasis depth and amplitude for each DS port.
But, as you know, HX3 Blaster Plus cannot use for HX2VL.
Hirotaka Takayama
Hi Takayama san
I understood.
Thank you for your reply.
Arai
