USB hosts hubs transceivers
TeMa_2997106
Contributor II
There is a phenomenon that the voltage drops to 1V for about 400ms during OS boot. It occurs on both the created board and CY4608.
Attach the waveform.
ch1 (yellow): U4 Pin1 (nENP1)
ch2 (blue): VBUS
My perception is that a reset is issued to the hub when the OS USB driver is initialized, and the HX2VL receives it and controls the Enable signal of the power supply IC. Is it correct? If yes, is this behavior as specified? Is there a time limit for making the Enable signal Inactive?
Tetsuo
Sananya_14
Hi Tetsuo-san,
Yes, my understanding is the same since the hub would remain connected to the host during reboot and the power enable nEP1 pin will not be asserted till a Set Feature (Port Power) command is sent from the host after Reset.
Please note that the timing is host dependent and you could take USB traces using an analyzer on the upstream port to help check if HX2VL is behaving correctly as per commands from the host.
Sananya
Sananya_14
Hi Tetsuo-san,
Sananya
TeMa_2997106
Contributor II
Sananya-san,
Thank you for your comment.
I can understand.
Tetsuo
