usb FX/CX3 camera video/bulklplowlevel data transmission to PC host
We are using a CX3 development board and trying to transmit a camera video and readings from an external sensor (connect to FX3 via I2C) to a PC host . We were able to get OV5640 video and readings using bulklplowlevel to a PC host separately, however, were NOT able to get both working at the same time. It looks like they both configured in a different way. Any advices?
Are you using FX3 or Cx3, a block diagram with connection interfaces will be helpful for us to comment. What is the expected data rate of the video.
What do you mean by not working? Can you tell if you are getting any error on the UART logs? Can you check which API is failing ?
Thanks Nishant, we use CX3 development Kit for this development. We are expecting normal video rate (1080p at 30 pps) and mid or low data transmission. We can not make both camera video and data transmission work at the same time while they can be working normal independently. As far as we know, we are NOT getting any error message and API issue. Any feedback would be appreciated.
project files
