IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
USB Superspeed Peripherals
     Recently, Microsoft released Windows 8 which supports USB 3.0 streams (http://msdn.microsoft.com/en-us/library/windows/hardware/hh406256(v=vs.85).aspx#_usb_host_controller...) , my question is:  does Cypress have a plan to update its CyUSB3 to support this feature too?
I need to check with the internal software team regarding this. I will update you soon.
Have you checked with the internal software team about this?
Yes Henry.
Current CyUSB3.sys does not support USB3.0 Bulk streams. Our software team has plan to add that support to it but the completion date is not known yet.
sai krishna.
 This might be helpful for you.
http://www.cypress.com/?id=4&rID=58178
sai krishna.
Thanks, I have already made it working now.
