speed of USB3.0 by streamer
 Hi!
I use streamer to read data from USB bord(3014). if I select 256 packets per xfer the speed can arrive at 320MBps. however after I detect the data I found that I lost some data. but if I select 8 packets or smaller the speed can arrive at 260MBps. but I can receive all the data.
So I want to ask that why I lost data with the larger number of packets per xfer.
many thanks!
dekui
What is the endpoint type being tested?
How are you checking the data loss i.e. are you dumping it to a file and checking or are you observing it in CATC and checking?
Anand
I am testing  the speed of usb3.0 in the streamer.when I set packets per xfer = 256 ,the failure=1,why?You can get it from img.
