Hi ,
For cypress gpiftostorage example ,which sd card is recomended by the cypress?
is it sdhc or sdxc?
please let me know sd card memory capacity used by cypress?
thank you
In FX3, SD/MMC controller can support SDXC. It has two ports that can support SD card upto 2TB size.
Thanks & Regards
Abhinav
Thanks & Regards
Abhinav
hi,
i know that,thanks for your reply,but i wanted to use same sdcard which was used by cypress already for my test project.please tell me the sdcard specification used to cypress project,thank you
I can't suggest you any one SD Card because here in cypress we had tested it with different SD Cards. You can try with Sandisk SD Cards.
Thanks & Regards
Abhinav
thank you,
we are currently using sandisk 8GB SDHC(not UHS-1) card for testing purpose ,is it proper/sufficient?
i have used sandisk 8GB sdacard in my project,before putting my sdcard into my project hardware,i have tested my sdcard by inserting in my mobile,it was working properly,but after placing into my project hardware,it is showing unsupported sdcard in my mobile?what whould be the reason?how to test sdcard hardware? help me
thank you.
