USB Superspeed Peripherals
DhN_4227681
New Contributor II
I am working on SD card, we want to write data to SD card which is coming from FPGA. Creating the DMA channel i.e GPIF II to SD card to write the data.
P to S0 channel for write function.
S0 to U channel for read function.
In control center its not giving any data, obtaining 997 error.
Please verify the below attachment file.
Dhanuja
Hemanth
Hi Dhanuja,
In the file attached, the DMA channel from S-port to U-port is commented.
Hemanth
Hemanth
Hemanth
Hi Dhanuja,
Hemanth
Hemanth
