fumac_3907466
I will use two fx3 usb to communication with my devices. When I use the friendlyname to get the usb name. I only get one usb name, and I only control the newest opened usb. how to control two fx3 usb simultaneously and respectively?
CCyUSBDevice*   m_pCyUSBDevice;
for (UCHAR i = 0; i < m_pCyUSBDevice->DeviceCount(); ++i){
        bool isOpen = m_pCyUSBDevice->Open(i);
        if (isOpen){
            QString friendly_name = m_pCyUSBDevice->FriendlyName;
Please follow up on the thread how to identify which one is removed?
Srinath S
SrinathS_16
To access the devices separately, the CCyUSBDevice->VendorID/ CCyUSBDevice->ProductID combination of the device's descriptor can be used. Alternatively, you can define a unique serial number string in the device descriptor and can be checked on the host application using the CCyUSBDevice->SerialNumber.
Srinath S
Thanks for your kindly reply. if i control two usb.
CCyUSBDevice*   m_pCyUSBDevice1;
CCyUSBDevice*   m_pCyUSBDevice2;
m_pCyUSBDevice1->Open(0);
m_pCyUSBDevice2->Open(1);
However, if remove one usb.
m_pCyUSBDevice1->Isopen = true;
m_pCyUSBDevice2->Isopen = true;
1. How to identify which one is remove?
2. If the removed one is inserted, how to open it?  I don't know which one?
3. Could you help to descripe the solution by codes more detail?
SrinathS_16
Srinath S
