USB Superspeed Peripherals
gean_3054931
Contributor II
i am using j link segger to debug fx3 firmware,when i am doing step by step debug by putting breakpoints, the event  CY_U3P_USB_EVENT_RESET is going to call many times? and its not going to the event state CY_U3P_USB_EVENT_SETCONF even with USB2.0 is connected to our fx3 custom board?what whould be the reason?
thank you.
KandlaguntaR_36
Since you are step into each line of firmware manually using the JTAG debugger, the USB call backs are getting time out.
Place a single break point after the connectstate API and remove all other break points.
KandlaguntaR_36
