USB Superspeed Peripherals
ZaTu_4258396
New Contributor
Thank you for the KBA. I realized that the period needed to be adjusted in order for this to function correctly. It was set to 66ms.
Now how do I get the ez-USB suite to stop shrinking all of my icons to being practically invisible.
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
KandlaguntaR_36
Please let me know whether you have changed eclipse setting.
How frequently it is reproducable?
Please share the steps to reproduce the issue.
Sridhar
ZaTu_4258396
New Contributor
I have not changed any settings in the eclipse environment. This issue has been a problem since I started with ez-usb suite. It seems to correct itself sometimes when I restart the application, but the error happens when the .exe gets called. I have looked up some info to change the .ini file for the following:
-Dswt.enable.autoScale=true
-Dswt.autoScale=200
-Dswt.autoScale.method=nearest
I just included that in my ez-usbsuite .ini file, but do not see a change in icon size when I play with the autoscale value. Any ideas?
-Zach
