USB Superspeed Peripherals
I am using cyapi.lib in a C++ project in Visual Studio 2015. Everything builds, and seems to work OK, but I always get the following link warning when I build:
warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs
I have looked online for solutions, but none of them seem to apply to my situation.
Does anyone know what might be causing this warning?
Is it something I can fix, or should I just suppress and ignore it (since my code seems to be working OK)?
You can just ignore that.
For more details you may refer:
http://stackoverflow.com/questions/3007312/resolving-lnk4098-defaultlib-msvcrt-conflicts-with
-Madhu Sudhan
