USB Superspeed Peripherals
Dear Sir
I get a problem of my FX3 superspeed design, and it has  confused me for two weeks, so please help me.
In my design I use many_to_one DMA channel which has 2 valid socket and every socket has 4 valid buffers,my problem is everytime I start a new transfer I always lose  random data after 8buffers have transfered,beside this my data received is continuous.
I am sure that FPGA always sends data  a little later than PC receives data.
I did not understand your problem clearly. Please help me in the same regard.
Following is your setup:
FPGA --> FX3 IN endpoint -->PC.
You have total 8 buffers in FX3 allocated for transferring data from FPGA to PC. Are you getting the right data when you are reading the first 8 buffers? Are you not receiving the right data after first 8 buffers?.
Please show me the data pattern logs, if possible.
Sai Krishna.
Hi Sai
Thank you for reply,and you get my point,I get the right data when I am reading the first 8 buffers and  I receive the right data after first 8 buffers,but between this two stage I lose data transfered from FPGA for about 1ms or more just like ProHerz encountered in http://www.cypress.com/?app=forum&id=167&rID=63294,
Thank you for help
Zhu
