USB Superspeed Peripherals
MaXi_1246331
Contributor
What is big endian and little endian for FX3 Firmware? When I debug FX3 firmware using segger GDB, I should choose little endian or bit endian in the GDB GUI.
YiZ_31
Big endian mode means most significant bit first and the reversed mode is little endian. This can be configured in the firmware.
The default setting is Big Endian for J-link, unless you changed the relating parameter in the firmware.
Eddie
YiZ_31
Eddie
MaXi_1246331
Contributor
thank you. the problem is solved.
