I have been working in the FX3 SDK 1.3.3 for a while. I tried to open a code written in the SDK 1.3.1 and it displays a lot of errors, like some typedef datatypes(uint8_t , NULL, etc..) cannot be resolved and warnings like 'Invalid project path'. I tried including the paths in Project properties-> C/C++ general -> Paths and Symbols -> GNU C -> Include directories which didn't help. Is there any way to resolve this problem??
Thanks in advance,
Ashlin Surey. A
I have tried the suggestions you gave that didn't help. I found out that I have not been using the ezUsbSuite in administrator mode. Then I ran it as Administrator and some problems like linking the library has been resolved. But now I get an error as System memory and data memory overflowed by 8272 and 21 bytes respectively. But the same code without any modification works fine in the SDK 1.3.1. I could change the memory addresses to resolve this but I still want to know the reason for this behaviour as this works fine in SDK 1.3.1. and also is there a way to resolve this error without changing the memory addresses.
Thanks in advance,
Ashlin Surey. A
Right click the project in the explorer -> Index -> Rebuild.
- Madhu Sudhan
Hi Ashlin,
You could try to click Project/C C++ Index/Rebuild to check if the problem still exists.
If you could build img file correctly, you could ignore these errors.
Thanks in advance,
Ashlin Surey. A
Hi Ashlin,
The ld files for different version of SDK are different. Maybe the EZ-USB build the project with different .ld files. Please check it.
I have added my own .ld file in the project. So I believe that both the SDK's would have used the same .ld file.
Edit: Also, I changed the memory map in my .ld file and now the project has been built. But I couldn't find the reason for this Memory overflow error in the latest sdk.
