USB Superspeed Peripherals
DaBo_288066
New Contributor
        Hi all, is there any method to switch on/off a PWM signal generated by a complex i/o? Once the i/o is configured by CyU3PGpioSetComplexConfig() it starts to generate the signal but if I want to stop and restore it? Can I only use CyU3PGpioDisable() and another CyU3PGpioSetComplexConfig() to restart? Thanks, DaX
Yes. you need to use the CyU3PGpioDisable. I am afraid there is no better method.
- Madhu Sudhan
