USB Superspeed Peripherals
lopo_1264666
New Contributor II
From "SuperSpeed Design Examples V1.2.1" and with CollectData set to "File To Receive".
Using Counter1.xsvf and defaulted GPIF clock (80MHz) for GPIF_Example1, found out that the gap = 56 forever using CheckData for File Transfer TimeOut = 20s. Next, I used command “PCLK-“ to reduce the GPIF clock to 50MHz and the gap reduced to 40 forever for File Transfer TimeOut = 20s.
Using Counter1.xsvf and defaulted GPIF clock (80MHz) for GPIF_Example2, found out that the gap alternates between these 2 values: 8192 and -8192 using CheckData for File Transfer TimeOut = 20s. Next, I used command “PCLK-“ to reduce the GPIF clock to 50MHz and the gap changed to -1 forever for File Transfer TimeOut = 20s.
Since gap = -1 represents perfect case where host computer can keep up with the counter count in CPLD while gap = positive number means missing counter count, how about -8192?
I don’t really understand the last statement returned by CheckData. TotalMissedSamples = summation of all gap values? How about the percentage analysis such as 2%, 1160%? I tried to plug in the numbers but couldn’t get its value correctly. Please refer to my attachment.
Hemanth
Did you get a chance to look at the following CheckData.cpp file in the below path:
SuperSpeed_Design_Examples_V1.2.1\SuperSpeed Design Examples V1.2.1\Visual Studio Projects\CheckData\CheckData
You can find the logic here.
Hemanth
Hemanth
Hemanth
Alternating 8192 and -8192 may also mean Host is not keeping up.
Hemanth
Hemanth
lopo_1264666
New Contributor II
I added in two printf() statement there to check “CorrectValue” and “FileBuffer” values. I was surprised to find out that new exe and old exe showed different results. For an example, using Counter1.xsvf and GPIF_Example1, old exe gives gap = 56 while new exe gives gap = 0 with default settings. I am not sure if I overlook sth.
while (BytesRead)
Success = ReadFile(ReadFileHandle, FileBuffer, sizeof(FileBuffer), &BytesRead, 0);
for (i=0; i<BytesRead/4; i++)
if (FirstTime)
FirstTime = false;
CorrectValue = FileBuffer[0];
else CorrectValue++;
TotalSamples++;
printf("\nCorrectValue = %ld", CorrectValue);
printf("\nFileBufferValue = %ld", FileBuffer);
if (FileBuffer != CorrectValue)
MissedSamples = FileBuffer - CorrectValue;
Value = FileBuffer;
FilePtr = &FileBuffer;
TotalMissedSamples += MissedSamples;
printf("\nGap of %d at index %d", MissedSamples, TotalSamples);
CorrectValue = FileBuffer; // Fixup for next sample
lopo_1264666
New Contributor II
Showing below is CheckData output where I used the same "CollectData.bin" file for both exe. The original exe showed gap = 56 but the new exe showed gap = 0 where CorrectValue tracks FileBufferValue and both count.
Hemanth
Please let me know which are the old and new exe you are referring to?
Hemanth
Hemanth
lopo_1264666
New Contributor II
New exe has these 2 extra lines of codes:
· printf("\nCorrectValue = %ld", CorrectValue);
Original exe showed this result:
Gap of 55 at index 4097
Cap of 55 at index 8193
Gap of 56 at index 12289
New exe showed this result:
CorrectValue = 88833281
FileBufferValue = 88833281
CorrectValue = 88833282
FileBufferValue = 88833282
Hemanth
can you please share the .bin file you used?
Hemanth
Hemanth
lopo_1264666
New Contributor II
The file size is huge ~ 3GB.
Hemanth
Please copy first 10KB of data into separate file and save it.
Hemanth
Hemanth
lopo_1264666
New Contributor II
I don’t know how to split and save the file.
There is another discussion “DMA watermark<https://community.cypress.com/message/227405#227405>“ with the same problem description and your colleague is getting in the CPLD board to duplicate my problem.
Hemanth
Okay. we can wait for reproducing the problem.
Meanwhile if possible, you can use Hex editor neo or HxD editor to copy first 10KB to a new file.
Hemanth
Hemanth
