tCFLG is increasing if I decrease PCLK frequency. Is this true?
If yes what is the maximum value of tCFLG at 100 MHz?
This should not be the case. tCFLG is specified as 8ns max.
Are you observing that the tCFLG going beyond 8ns? If yes could you please let me know how exactly you are measuring the tCFLG. It should be measured from previous clock edge to FLG valid.
sai krishna.
